Converter choice
Old Sep 27, 2009 | 05:35 PM
1mean96ss's Avatar
Default Converter choice
I should have my th350 done this week but if i dont i plan on putting my 4L60 back in the car. I had a 3600 with 3.90's and a 26'' tire. Now i have the same gears and 28'' tires. the car is heads/cam (232/232 .608/.608 on a 108). Will be spinning between 6200-6500. Need to pick a converter size for the 4L60 since i have 28s now
When the th350 is done it will get a 4000 plus stall.
Old Sep 27, 2009 | 05:59 PM
Yank's Avatar
Call me on Monday if you would like to talk about your set up
Dave 775 826 9955
Old Sep 27, 2009 | 09:14 PM
1mean96ss's Avatar
I will plan on it, thanks.
Old Sep 28, 2009 | 07:34 AM
Circle-D's Avatar
Is this going to a mostly track car or a weekend toy? If you plan on keeping the 4L60e in it, then I would do a 4000+ for it as well. If you will be swapping to the 350 when it is available then just run your 3600 and save a few bucks. We have numerous options for either trans and be glad to help you select one.
713-895-8834
Chris
Old Sep 30, 2009 | 02:52 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
give me a call as well and see what I have to say. I would like to talk about your future with the car and some more specs would be needed to properly select a stall for yur car.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Sep 30, 2009 | 03:17 PM
meatman's Avatar
Any of the above would be a good choice.
