Older 4L60E run off LS1 Computer
Old Oct 2, 2009 | 06:05 AM
frankmarroquin's Avatar
Default Older 4L60E run off LS1 Computer
How true is it that a LT1 4L60E can be run by a LS1 Computer? They will bolt up together right? Minus the Torque Converter....?
Old Oct 2, 2009 | 01:24 PM
performabuilt's Avatar
LS1Tech Sponsor
As long as it a 96 up there are no issues with control . Earlier units can also be adatped electronically.
Bolt up is direct but converter requires a sleeve in the rear of the crank .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 2, 2009 | 01:31 PM
Thanks you... But where can I get that sleeve or what does it even look like? By anychance do you supply them?
