4l60e delay shift into 3rd.
I would say 99 percent of the time if the shift is solid but just not happeing when it should its PCM/SENSOR or Tuning related.
to set this up.
2 LEDs from radio shack 12 volt (not light bulbs)
2 lengths of wire in two colors about 12 foot each.
2 snap splicers.
wire the led neg side one to the lt green wire the other to the yellow wire with black stripe note which is which.
The other end goes to 12 volts in the car put the leds in a box or somewhere you can see them .
BOTH ON=1ST
LTG OFF-YBLK ON=2ND
BOTH OFF=3RD
LTG ON-YBLK OFF=4TH
You can also wire a third LED into the TAN WIRE w/ BLACK STRIPE and see when lockup is being enabled/ disabled.
When you see these LEDs going off and on you know for sure whats really being commanded not just guess by what should have happened.
