Loose or tight ?
Old Oct 13, 2009 | 10:39 PM
GatorFan08's Avatar
Default Loose or tight ?
ha. Which converter is better for nitrous? A loose converter or a tight one? MY car right now has a 3600 vig and its extremely looooose!
Old Oct 14, 2009 | 12:59 AM
99Hawk262's Avatar
A tight converter...it'll loosen up plenty when you spray it!
Old Oct 14, 2009 | 01:24 PM
SOMbitch's Avatar
Old Oct 14, 2009 | 08:41 PM
Circle-D's Avatar
You will want a converter that is built for the spray, not just the for the motor. Lets say you get a 3800 for the motor and it works great. But when you spray it with the N20 it will increase the stall and re-flash the converter to 4500+??, thus practically wasting the extra HP to heat in the trans fluid. So you build a 3800 for the nitrous so when you spray it only goes to 3800 and the extra power gets to the tires.
Chris
Old Oct 14, 2009 | 10:54 PM
GatorFan08's Avatar
Thanks guys
Old Oct 15, 2009 | 08:48 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Ditto on chris. A nitrous converter is a totaly diffent animal than a motor converter. Blade angles,stator blade count and clearances must be different for a nitrous peice. We do a lot of nitrous converters such as Petes nova that just set the world record at 4.88 at 148 on 275 drag radials and leaf springs(tock suspension) at 3300 lbs.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Oct 15, 2009 | 09:30 AM
Yank's Avatar
Here is some of the offerings we have for you
http://www.converter.cc/converters/street/GM/1/
Thanks for looking
