no 2-3 shift at wot.
Old Oct 17, 2009 | 08:19 AM
12leavu's Avatar
Default no 2-3 shift at wot.
im running a 4l60 in my fd rx7 and a b&m shifter. the trans does not have a mlp switch nor does the shifter. my problem and question is i cant get it to shift wot from 2nd to 3rd. it drives fine at normal throttle, but it never shows 3rd on a scanner. even if it is in 3rd. it just goes 1,2,4 on the scanner as it shifts thru. it holds 3rd gear fine if you manually hold it in third, but if you leave in d. it will not shift into 3rd a w.o.t could this have anything to do with not having a mlp switch. ive already tried lowering the mph in my tune by 10 mph.
Old Oct 17, 2009 | 08:37 AM
MUSTANGBRKR02's Avatar
Try zeroing the MPH field out and see if it shifts then. This will eliminate it being mechanical. Have you raised the rev limiter?
Old Oct 17, 2009 | 09:35 AM
12leavu's Avatar
its at 6800, id hate to raise it much more. havnt tried zeroing out yet
Old Oct 17, 2009 | 11:16 AM
Try zeroing that out and post back up.
Old Oct 17, 2009 | 11:38 AM
12leavu's Avatar
do you mean part throttle and wot ?
Old Oct 17, 2009 | 03:39 PM
try one then if that doesn't then try both.
