Need help quick with a trans leak
Old Oct 19, 2009 | 03:23 PM
streetassasin's Avatar
Default Need help quick with a trans leak
Ok, its leaking where the grey connector on the passengerside connects to the trans itsself, I can see the fluid coning out, any idea on how to fix it?
Old Oct 19, 2009 | 03:41 PM
Badazz 97 TA's Avatar
new harness or just the o-ring. i forget what it looked like on the other side. i know the claws of the connector that hold it to the case make a leak free area by keeping pressure on it. i paid 85 bucks from GM for the harness that i had to put in for a temporary trans i had to use during winter last year. i had a similar leak from the same spot.
either way the pan has to be dropped since thats how you get the connector out form the trans case
Old Oct 19, 2009 | 05:59 PM
appreciate it man, somehow the connector worked itself loose and I was able to push it up and lock it in place
Old Oct 19, 2009 | 08:07 PM
no problem man. Hopefully that fixes it.
