Need Trans Swap Info Quick Please
1)d/c both lines, and plugs etc.
2)drain pan, lucky got a plug!
3)remove bell bolts
4)remove driveshaft
5)remove crossmember
6)drop trans on chest, scream for help and slide out under car
What am I missing?
Charlie.
Use new converter bolts if possible, and use Loctite Blue on them. Also, you'll need to pop out the 2 clips on the lines to remove the cooler lines. Put the clips back in the trans while it's out, or they're a bitch. The lines just snap back in later. Use steel wool or scotchbrite to clean the rust off the driveshaft yoke while it's out. That will extend the life of the rear seal.
It's pretty straightforward though, you can always ask questions here if you get stuck
