400 Trans brake
Unless you have a mill, EDM machine, and some mad skills, it ain't gonna happen.
Go buy a valve body ready to go. It's not just a solenoid.
You need a brake valve to replace the modulator valve, and the VB requires milling slots, plugging bores.
You have to make a new seperator plate to re-route fluid.
Get a hydraulic schematic and figure it out. That's how everyone else does it.
Some bores also have to be sleeved. You're also going to have to make a t/b valve. And don't forget about the direct drum stuff.
