Performabuilt lvl2 Yank4000ss Overheating?
You said it did this with the stock trans right after you put the stall in, and now its doing the same thing now with the new tran. Check your lines make sure thiers no bend in the line and check your tune. Let use know what you come up with. Good luck.
everything with the lines looks fine and i also just installed another cooler... so if this doesnt fix it i know it has to be something computer related. The main thing i worry about is the fact that when i drive for a period of time and then it just revs high but doesnt want to move. Everyone i ask has never had this problem so its just very frustrating.
My stock trans did the same thing every time I had been driving it for a while. I would pull over and let it cool off and it would be working fine. So maybe you do have cooling issue. It might help a little if you got the cooler off the condenser but that other cooler should solve the problem.
The ac is out of the car so that shouldnt be an issue the 2 coolers are mounted in front of the radiator now. So far no issues, but it hasnt been out much since i installed both of them.
