4l60e ?
Old Nov 9, 2009 | 12:51 PM
pddye's Avatar
Default 4l60e ?
I'm switching my car back to stock from the th400 to a 4l60e I bought from a member on this board and am having some problems. I got everything in and up and running and for what ever reason i'm getting the codes on my hp tuners scanner of -
[PCM] P0740 - TCC Enable Solenoid Circuit Electrical (Pending) (Old) (Current) (Immature)
[PCM] P0753 - 1-2 Shift Solenoid Circuit Electrical (Pending) (Old) (Current) (Immature)
[PCM] P0758 - 2-3 Shift Solenoid Circuit Electrical (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0785 - 3-2 Shift Solenoid Circuit Electrical (Pending) (Old) (Current) (Immature)
[PCM] P1860 - TCC PWM Solenoid Circuit Electrical (Pending) (Old) (Current) (Immature)
I also took a tune off of hptuners to reput in all the stock info on the car related to the transmision tables.
When running the car it stays in the 1:1 ratio, but I can down shift the car the gear below it (I'm guessing that is second). I guess this would be an electrical connection of some kind not working but i've checked my harnesses and they seem to all be in place. Or could it be a faulty tune? This is just a stock trans and stock converter setup. Right now i'm baffled why the trans won't electrically control itself.
Any help would be appreciated.
Old Nov 9, 2009 | 03:27 PM
performabuilt's Avatar
LS1Tech Sponsor
sounds like a blown fuse no power to pin E on the trans connector
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 9, 2009 | 04:14 PM
pddye's Avatar
I've been looking for a schematic on what voltages should be on each pin but i've yet to found one. Would you know which pin would be that E pin? Also I've been checking into all the fuses but which one would control that? I'm guessing a fuse got pulled on the original th350 install or a wire got cut but I can't track it down.
Old Nov 18, 2009 | 06:48 PM
pddye's Avatar
Found it was the 15 amp fuse called ENG CTRL. I never would have guessed that was the one until I bought a 1 year trial for my car on www.alldatadiy.com . Its a very helpful website with any schematic you might need.
