4L80 problems help please!
Old Nov 24, 2009 | 06:27 PM
setxathlete14's Avatar
Default 4L80 problems help please!
hey guys i just put in a new 4L80E and converter in my 01 GMC truck about 8 months ago. The check engine light has been flashing about 8 times and going away quite often. and yesterday it started whinning. Then today when i was driving it the transmission would slip real bad. seemed like it would get worse the higher the tranny temp was. im HOPING the filter is clogged but wouldnt be logical because of how new it is. next bet is the converter? what you guys think?
Old Nov 24, 2009 | 09:29 PM
robert miller's Avatar
It could be the bands are going out if this wasnt build right. If a shop put it together for you have them to look at it. The 4l80e will take about all you can put to it if build right. I have one in a 57 chev with a dart 540 c/u big block in front of it. Have not one moment of problem with it.
Old Nov 25, 2009 | 08:31 PM
everythings brand new fromm GM. fluid level was good and pink but smelt slightly burnt,
Old Nov 25, 2009 | 10:21 PM
MY99TAWS6's Avatar
Well I would have been reading those codes..Then you might have idea what happened or is happening. If its new isn't it on warranty?
Old Nov 27, 2009 | 10:59 PM
code wont read. it only flashes then cut off. im thinking it could be the TCM or converter.
