Will a GTO automatic work in a 98 Z28 ? I believe the GTO trans is a 4L65e so the dimensions should be the same,is there any thing that needs to be changed over to make this work?
Shift linkage shaft and tail housing and you should be good to go
To get the 4L65e it needs to be from a 05 or 06 right ? the 2004 GTO was a 4L60e. Second question is will my 4L60e torque converter work in the GTO 4L65e
