need help with trans fluid,A4?
Old Jan 7, 2010 | 08:54 AM
allan808's Avatar
Exclamation need help with trans fluid,A4?
1) how much quarts do yall put in a 4l60e and what oil is best?
2) do you change the filter,if so what filter do yall use?
3) where do you drain and fill the trans?
thanks in advance!
Old Jan 7, 2010 | 10:20 AM
Badazz 97 TA's Avatar
1: depends on the size of the converter and type of pan your using
2: GM replacement.
3: You fill the trans through the dipstick tube. Draining it is another story. If the pan has no plug then you un-bolt the pan then about 4 quarts ends up on the floor OR all over your clothes. it sucks lol
Old Jan 7, 2010 | 03:53 PM
allan808's Avatar
its stock stall etc..i just want to replace the fluid and filter..the car is a 98 trans am..
Old Jan 7, 2010 | 04:58 PM
By dropping the pan you will need approx 5qts of fluid. You can hit up a local parts store for the parts. Dex 3 fluid. Any brand of your choice.
Old Jan 7, 2010 | 05:40 PM
Bill Bowling's Avatar
It is also good to have the trany flushed every once in awile. It cost about $75 + but you then know all your fluid is clean not just 4-5 qts.
Bill
Old Jan 11, 2010 | 12:37 PM
Squirts11's Avatar
Bill
This is at your own risk. I've heard plenty of horror stories regarding high-milage cars getting the tranny flushed...then
Old Jan 12, 2010 | 10:57 AM
MadIceV8's Avatar
Customizing Director
This is because of an already preexisting problem (from probably not changing the fluid).
