please help 4l60e leak
Old Jan 23, 2010 | 09:00 PM
Pseudonym's Avatar
Default please help 4l60e leak
I have a built 4l60e that I took off my LS1 and installed on my LS2. It worked perfectly on the LS1, but on my new motor it is leaking like crazy from the passenger side, near the trans cooler line connectors. I removed the connectors and saw that the O-rings had been split, so I replaced them, put teflon tape on the connectors and reinstalled them, but it is still leaking.
Any ideas on what is causing this leak?
Thanks in advance
Al
Old Jan 23, 2010 | 11:39 PM
performabuilt's Avatar
LS1Tech Sponsor
Beware the teflon tape I have seen the case crack at the threads from using it if too much is used. You need to clean up the area and let dry then start car and use a light and watch and see exactly where the fluild is coming from over there.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 24, 2010 | 08:04 AM
Pseudonym's Avatar
Should I take the teflon tape off and just use a liquid thread sealant?
Old Jan 24, 2010 | 09:55 AM
LS1Tech Sponsor
well if its in there now and didnt crack the case I would leave it there. For now I would clean and verify the exact location of the leak.
__________________
Call 888-744-6542
Old Jan 24, 2010 | 10:56 AM
Pseudonym's Avatar
The retainer clip on the connector fell out. I got a new one at a local auto parts store, and all is well. I'm glad it was a simple fix.
Big thanks to PerformaBuilt for the quick responses and the awesome transmission.
