Vote on what trans i should use in my 63 turbo nova
Whats up guys i have been building this 63 nova with a competition eng. Back half and coilovers 4:56 gears mw 9" 16.5 et streets with a tsp 408 and a 88mm bw turbo...what tranny do u guys think i should run a powerglide or a th350 i will drive this car on the street from time to time...thanks for the help!!
k...WHAT DO U GUYS THINK OF REDNECK TRANSMISSIONS THEY HAVE A POWERGLIDE GOOD TO 900HP WITH STALL FOR UNDER $1500
http://cgi.ebay.com/ebaymotors/GM-PO...Q5fAccessories
LS1Tech Sponsor
Powerglide only!!!. You will probably need a little better trans than the unit listed. We have glides in stock from 1000 hp to 3000 hp. we also build the converters that go with them. We would need all the info on your combo to spec one out. We also have the filler tubes and all other related items for the install. give us a call 1-866-726-8358
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
![](https://ls1tech.com/forums/signaturepics/sigpic99412_4.gif)
well the car is a 63 nova with a 408 and a bg s488 mm turbo with about 15 psi of boost 100# injectors about 2800lbs or so total weght....what powerglides and converters do u offer that would handle aroun 1000 HP
