Flexplate for LS/Powerglide
I am wanting to put a 6.0 in front of my powerglide/350 converter. Does anyone make an aftermarket flexplate that will bolt up to the LS motor and old transmissions and converters? I know a lot of people use the 6.0 spacer and stock flexplate but I am worried about strength, converter fitting in the crank and the starter not reaching if I do that. What is the bast way to do this?
Dan
Dan
I found this today. http://www.summitracing.com/parts/HUP-HP4004/
Will I still need a "spacer" for my converter with this flywheel?
Dan-o
Dan-o
buy the tci flexplate it comes with the spacer...or buy the hughes flexplate and then buy their spacer....or just run the factory flexplate and enlarge one of the bolt holes a little and buy the spacer...there is 3 options off the top of my head
We have trhe billet aluminum SFI approved flexplates with the bolt on ring gear for 289.00
Give me a call at 1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
