HP loss between th400 and 4l60e?
Old Dec 25, 2003 | 10:45 PM
kevinb's Avatar
Default HP loss between th400 and 4l60e?
Will there be much loss or gains going from a 4l60e to the th400. I know how the th400 compares to a th350 but don't know how it compares to the 4l60e. Also, are weight differences great? Thanks!
Old Dec 26, 2003 | 12:03 AM
'01 WS6 TA's Avatar
I don't know the exact % of loss there is, but most see some. I don't have any before dyno numbers w/ the 4L60 with my current setup. With my bolt on car, a 12 bolt and 3.55's in the rear, and a 3600 converter my car made a best of 321 RWHP and 438 RWTQ. The torque number is a spike of course b/c of the converter. Hope this helps.....
Old Dec 27, 2003 | 02:00 AM
GrapeApe's Avatar
i heard do do rob a bit
Old Dec 31, 2003 | 09:34 PM
BLUEBALLS ZZ's Avatar
i would think it would rob anymore then the stock tranny hp wise. but internal gearing is what the big difference is. i seen i guy go from high 114 traps to 112 traps from m6 to turbo 400 swap. hp wasn't measure from before so i could give you any dyno numbers.
Old Dec 31, 2003 | 10:09 PM
z28hokie's Avatar
Depends on the transmission. ATI has some lightened TH400's which have a lower weight rotating mass- these would have less horsepower loss than say the 1970 TH400 sitting in my garage...haha
One nice thing though is the 1-2 shift won't loose you as many Revs...
Old Jan 1, 2004 | 11:40 AM
flyinZ's Avatar
What about the TH 350??
Old Jan 2, 2004 | 03:23 PM
BigPlanTransAm's Avatar
TTT
a converter with a good shift extension lessens the revs lost from 1-2
