Transmission fluid change
Old Dec 26, 2003 | 12:49 AM
LS1 Brent's Avatar
Default Transmission fluid change
I'm wanting to change my transmission fluid in my 4L60E to the F-Type fluid. Is this something I can do myself? If it's probably too difficult what are some good shops that will do it? And also, how much would something like this cost me? thanx alot.
-Brent
Old Dec 26, 2003 | 01:42 AM
DeepBlueZ's Avatar
i dont recommend it. A friend of mine put it in his tranny and it banged the shifts so hard, he glazed his 3-4 clutches in 1000 miles....4 different times!
Old Dec 26, 2003 | 03:35 AM
BlackWS602's Avatar
what's wrong with plain old non synthetic dexron?
Old Dec 26, 2003 | 06:09 AM
destroyerSS's Avatar
just go to a shop you trust and have them do a full trans flush with a trans flush machine then top off with a good additive such as lubegaurd red or BG's additive. Prior to the flush they should add a can of cleaner to your trans and test drive it for about 15 minutes. This process of flushing works great! BTW use a quality NON synthetic dextron fluid
Old Dec 26, 2003 | 09:54 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Absolutely nothing!! It's the only stuff I use.
When I bought my trans at FLP that's what they told me to stick with.
Old Dec 26, 2003 | 12:26 PM
BlackWS602's Avatar
The only thing I don't like about the machines is the filter usually doesn't get changed, and any crap that might be stuck to the pan doesn't come out.
Old Dec 26, 2003 | 12:55 PM
At our shop we give you the option for us to drop the pan after the flush for this exact reason. A new filter clean out the pan and a new pan gasket. But it's a good point to bring up. Later Shawn
Old Dec 26, 2003 | 01:02 PM
BlackWS602's Avatar
Exactly, most shops I know never ask you that, you usually have to tell them to do it if you want it done. So it's just a FYI for the guy wanting it done
Old Dec 26, 2003 | 04:40 PM
ULTIMATEORANGESS's Avatar
the shop where i had mine flushed was done at the pump.flushed and serviced.why is everyone so against syn?
Old Dec 26, 2003 | 04:54 PM
where the hell did they hook to the pump? there is no service point there. Was the trans still in the car? I think what they must of told you is thst the flusher is run from your pump. cause every flusher i've ever used hooks in line at your radiator & trans line
Old Dec 26, 2003 | 05:28 PM
ill try to explain how it was done.the pan was dropped.they used a part to hookup in the pan then hooked up the machine and flushed it from there.
the shop also told me shops that flushing from a trans line is prone to have leaks.how do you tap into a line?this shop told me most shops cut into it and thats no good.
Old Dec 26, 2003 | 06:32 PM
BlackWS602's Avatar
synthetic fluid in an A4 will actually cause the clutches to slip more than usual resulting in more heat, which results in early tranny failures. Heat kills trannys.
Old Dec 26, 2003 | 07:30 PM
so they removed the filter and went in from there but VERY UNESSASARY!!!!Was your car running or was it off? and were they using a flush machine that is normally used to flush lines before a new trans install. Because there is no cutting involved in doing a trans flush all you do is unhook the trans line where it goes into the radiator screw on the fittings and flush. Our shop uses a BG flush machine and it comes with all the different fittings to do just about all cars and it takes about 1hr with a full flush and filter change
Old Dec 26, 2003 | 07:52 PM
Jorday's Avatar
Type F works just fine in my A4.
Old Dec 26, 2003 | 08:45 PM
RPM WS6's Avatar
I too am 100% anti-syn for the trans. Super slippery = NO GOOD for clutches.
Old Dec 16, 2007 | 11:03 AM
albertson_jay@yahoo.'s Avatar
Anyone hear of doing a flush yourself by removing the inlet cooler line, attaching a hose and pump the fluid into a bucket by starting the engine. as soon as the fluid stops you turn it off. then reconnect the cooler line, drop the pan and replace the filter and service as normal. Could this hurt the tranny to run dry just for a moment?
