need help seperating bellhousing!!!
Old Feb 13, 2010 | 04:19 PM
stevez2885's Avatar
Default need help seperating bellhousing!!!
trying to seperate bell housing from motor and tried heating up with a torch after using a nut buster compound and still nothing....anyone got a better way to seperate? thanks guys
Old Feb 13, 2010 | 06:31 PM
stevez2885's Avatar
tons of views but no one has any ideas?
Old Feb 13, 2010 | 06:32 PM
ws6fitz's Avatar
I take it the motor and trans are out of the car?? If so take a ruber hammer and hit along all the edges of trans then repeat and hit it so that it will break apart. had the same problem with mine and that worked for me.
Old Feb 13, 2010 | 06:36 PM
stevez2885's Avatar
motor and trans are still in car and tried prying and torch etc and shaking it lol cant get anything to budge
Old Feb 13, 2010 | 06:42 PM
ws6fitz's Avatar
did you make sure that all the bolts are out?? i know that sounds stupid but there is one bolt that is all the way at the very top of the trans that is a pain in the *** to get out.
Old Feb 13, 2010 | 06:44 PM
ws6fitz's Avatar
also did you take the plastic coverers off the trans so you are able to see the converter?? You could pry from there as well.
and did you drop the k-member down to give the trans clearens to come out?? it wont come out of the trans tunner in the floor if you dont.
Old Feb 13, 2010 | 06:57 PM
stevez2885's Avatar
plenty of clearance now and all bolts are out including the one that is very top center
Old Feb 13, 2010 | 07:03 PM
ws6fitz's Avatar
Not sure then man, i would just keep prying from different angles then and try the rubber hammer in there.
Old Feb 13, 2010 | 09:26 PM
spyterus's Avatar
I used a large flat screwdriver and a crow bar, putting them between the block and the bellhousing. Move it little by little, you don't want to crack the housing by giving to much force. It took me over an hour doing this but it finally broke loose. What happens over the years is the heat generated by the engine fuses the aluminum together. It will come off eventually. Good luck.
Old Feb 13, 2010 | 10:25 PM
stevez2885's Avatar
thanks for all the hep guys but this is the 3rd time taking my trans out in 3 years lmao. hopefully better luck tomorrow
Old Feb 13, 2010 | 10:56 PM
Badazz 97 TA's Avatar
3 times already. sounds familiar. Is that with the performabuilt trans?
make sure the trans is level and not sagging down on its own weight. Supported by a jack. Sometimes the weight can cause the bellhousing to jam up on the dowel pins
Old Feb 14, 2010 | 10:28 AM
stevez2885's Avatar
thanks badazz and yes ive had nothing but problems with performabuilts trans/converters.....luckyily this time its their converter and i went with circle d for my replacement....lmao it blows again here i go t56 swap
Old Feb 15, 2010 | 03:55 PM
heymoej's Avatar
[QUOTE=stevez2885;12892085]thanks badazz and yes ive had nothing but problems with performabuilts trans/converters.....luckyily this time its their converter
sorry to hear about your problems.......
let us no how you like your new circle d....
Old Feb 16, 2010 | 01:14 AM
SoundsZ28's Avatar
i had the same problem in one of my cars.. trans wouldnt budge. i ended up getting a ratchet strap, finding a good spot on the trans to mount it/ wrap it to and started ratchting.... still wouldnt budge and i couldnt ratchet anymore so one i started prying slowly it finally gave.. GL and when you re-install it use some antisieze around the dowel pins
