Starting 4L80 Install, Couple Questions
Old Mar 9, 2010 | 07:38 PM
forcd ind's Avatar
i cant make out the bottom fitting, but the top one is from a turbo 400 or 350, takes a flare fitting, used the old stle 5/16 cooler lines-they should be removed if you have new fittings with 1/4-18 straight threads (npts)
Old May 27, 2010 | 03:32 PM
Photochop's Avatar
Originally Posted by slow67
You will need a counter-bored yoke. The last ~1" of the yoke will be smooth so it can go over the fat part of the shaft and o-ring.
So would this be the one to get if adapting to my stock aluminum driveshaft?
http://www.dennysdriveshaft.com/p69_...pline_wth.html
Last piece to this little puzzle.
