4l60e re-fresh with pics
As far as the 3-4 load springs go, they will always be in any transmission(4l60e) I do. I will never use the stiff return springs in the apply piston area, it just isn't a problem with my tranny. The load springs that install along side of the 3-4 pack just makes sense to me, Its seems like they "help" the pressure plate return with the #7 apply ring to keep the 3-4 from dragging.
There is many different ways to assemble this tranny and many high performance places even do it differently. I think this way works best for me, although I cannot say other ways are not as good.
Thanks for the response and keep checking for more photos as I near the end of this build.
this is the second time w/o one, and it is only $40
good job soo far btw
The reverse input drum sits on top of the input drum, lots of wiggling to get all the clutches to spline in. Then pick up the entire set and again wiggle, move, shake it to get the splines and sun gear to mesh into the case. You know your have seated them by the reverse drum sitting lower then the pump mating surface(where my finger is) also you can hold down on the reverse drum, and you will be able to lift up on the input shaft about 3/8 inch or so.
Some people put the band in first, but I have always been able to install it after the drums are in. Now install the band pin.
2nd and 4th gear use the same and only band in this tranny, having strong servos is a must in my book. Here I have the wide band, used with a new(ish) drum that is not damaged at all and is perfectly flat.
With these servos being pretty new I was just able to clean them up, seals looked good and were not brittle or hard. I was able to replace the 2 bigger o-rings that was in my rebuild kit. But keep in mind a normal rebuild kit will not supply new seals for these servos, you may have to contact the company or a certain supplier.
Getting closer to the car running, should be done tomorrow or at least very close to it.
I cleaned the valve body to get all the **** out of it. mostly looked good, no damage, no wear. I removed the valves one at a time and mad sure they slide freely in their bore.
I matched up and measured some of the feed holes from my old separator plate to the new transgo unit. I cannot believe how big some of those feed holes were.
Again please understand this is just a small write-up on me going through my tranny pre-season. Do not take this as a how to beef up my tranny thread. I wanted to do this just for tips and to show everyone whats inside these trannies.
I drill 2nd gear feed hole to .093 and 3rd gear feed hole to .100 only with the billet servo, with the corvette servo go .093 on the 3rd gear feed hole
Rest of these tranny goes together and slide under car for installation.
I'm kinda tired not, almost got the car done( I was dirty so i didn't want to get in the car), just fill with fluid, and test drive left
wish me luck!!!!!!
-fill converter with some fluid before install
-valve body bolts are different lenghts....make sure they go in specific location!!!
-Bell housing bolts are a torx plus 50 size....do not use regular torx bit.
-Keep all parts clean, take your time, and don't forget to flush out cooler.
