ATT: LQ4 6.0 / 200R4 / 700R4 Users need help
i'm getting ready to put my motor in the car .. just found out my ARP flexplate bolts are too short , my motor has the .400 spacer on the crank , and i'm using a TCI flexplate (399753) do i use the factory bolts? take the spacer off ? or will the starter not line up correctly ? also the TCI flexplate is
.200 thicker then factory.. i've read 6.0 w/ 4l60e dont have the crank spacer , trucks with the 4l80e do have the crank spacer.. but i'm not using either of them transmission ..what do i need to do ?
does the TCI flywheel have the small thin spacer screwed on the back? if so it goes on w/o the spacer-as i remember from a while back, if you meas from the back of the block (where the trans mounts) to the back of the flywheel teeth, its around 7/16" or so, for proper starter alighnment-then you may need a spacer that regs. into the crank (it slips into the crank, no bolts) and regs. into the converter
the TCI flywheel i used was for a 4L80E replacement, came with the spacer, i was trying to use it with the spacer at first, def was a little confusing
my concern is if i take off the .400 factory crank spacer wil the converter be sticking out of the trans too much ? but my TCI flexplate does have round sleeves welded to it where the converter mount to it .. does that keep the converter spaced in towards the tran when the factory spacer is removed.. i bought the flexplate used so no instruction where given ....thanks
