Those with aftermarket converters...
By the way, if you'd like, please list your best times. 60 ft., 1/4, MPH, etc.)
Mods/pertinent info:
2.73 diff
ST3500 TC w/2.5 STR
FRA
Home ported/epoxied TB
NGK TR55 plugs @ .055" / MSD 8.5 plug wires
Stock 16" wheels w/ 245/50 Khumos
Self-modified thermostat and early fan turn on via HPP3
Rev limit / shift points / shift firmness / tire height adjustments via HPP3
25000 GVW trans cooler routed on return line to trans
Directflo air lid/ K&N filter
Strangely enough, I once got about 30mpg on an early morning cross-state trip where I seldom got below the 100-120 mph range. (not recommended).
I get about 18 in the city. 23 on the highway. In the city i get alittle better mileage if i give it some gas. If i putt around the converver slips at 1800 and it stays there longer. Give it more gas and it changes gears faster. Plus its more fun and costs less. Tell you the truth i didnt notice Any change in gas mileage after the converter. Now the cam thats a different story
Never take long enough expressway trips to watch highway mileage.
1/4 = 12.110 @ 110.54 mph
60 foot = 1.66 seconds on a 17 inch drag radial
converter specs on this run were a TCS 9 inch 3400 stall 2.5 STR
new converter is a Vigilante 3200 (really more like 36-3800) 9 inch, 2.5 STR
(no times with this but it seems a tenth or two quicker with same mileage)
22mpg city, cant measure highway..I live on a small island in the S.W. Pacific ocean!
Best 60' = 1.51 pulling the fronts
11.01 @ 122 tame *** verter, but guess it works.
