4l60e atf
Old Mar 15, 2010 | 08:34 AM
green28's Avatar
Default 4l60e atf
Getting ready to do a converter swap and wanted to know what type of ATF do you guys preferred to use and what type/brand of filter should I get? Any type of Dex III work just fine? I read somewhere on here that I'll need 8 quarts to fill the tranny and another quart to pour into the new stall. Does that sound about right?
Old Mar 15, 2010 | 09:46 AM
01ssreda4's Avatar
With just a converter swap, you are prolly looking at 4-5 quarts total. I have run the Castrol Dex for the past few years with no issues.
Old Mar 15, 2010 | 10:40 AM
green28's Avatar
I'm just dropping the pan before I drop the tranny down, so basically the 1 quart or less to pour into the new converter and 4 quarts to replace whatever came out from dropping the pan and I'll be good to go.
Old Mar 15, 2010 | 10:58 AM
MadIceV8's Avatar
Customizing Director
Anything Dex III should be just fine. I just run Pennzoil in my FLT5.
Old Mar 15, 2010 | 04:35 PM
biggb1783's Avatar
i am probably gonna get flamed for this but i have been using type f in my trans for over ten years now with a 3600 vigilante converter with a transgo shift kit ect...... I used type f in my 700r4 (sold the car)and i still use it in my turbo 400.
I am not saying you should do the same but i tend to stick with what i know works.
Old Mar 15, 2010 | 06:42 PM
Kevin01Z28's Avatar
Originally Posted by Bro Inc
I use the cheapest Dexron available.
For a filter I prefer a SPX Filtran filter. Or anything made in the USA, even though they usually come in a kit, buy the Felpro fiber gasket and throw the one in the kit away.
FWIW take a china filter, cover the sump end with your hand and blow through it, they leak like hell. I know no one give a ****, but do the same on an SPX filter and it's tight.
Who sells SPX? I have one from Orielly's and its a pioneer. Says its made in the U.S. on the box, and on the label it says made in Taiwan
Old Mar 15, 2010 | 08:36 PM
Kevin01Z28's Avatar
Caught my interest since im about to change my trans fluid. I know most of the aftermarket stuff at the parts houses is foreign.
Old Mar 16, 2010 | 11:15 AM
MadIceV8's Avatar
I have read about plenty of people running type f as well. Apparently it increased shift firmness. I have never had experience with it and will stay with Dex III as recommended by my builder.
