Full Manual 4L60E
With the full manual its just simply you move the manual valve and the oil is imediatley directed to the apropriate clutch set or band. Sorta a no middle man type deal.
Is this going to shorten the life of the box considerably or can they be built to last with full manual?
I've got a vacuum modulated, MVB 4L60 in my car. The 1-2 shift happens about 1 second after you shift it, and the 2-3 shift happens about 2 seconds after you shift it. Thus, I have to shift early to hit the shift pts I want. Does this have anything to do with the modulation, is it a valve issue, or is it just a neccesary evil? This happens just cruising or at WOT, the hessitation is nearly the same.
