4L65-E in the C6
Old Jan 12, 2004 | 07:46 PM
DeepBlueZ's Avatar
i noticed you mentioned the beast....for anyone looking for a sunshell i highly recommend it, you almost never hear of those breaking....
Old Jan 19, 2004 | 09:25 PM
MMarquez's Avatar
I noticed that the shift points are lower also. What exactly does that mean? Is it the programming of the shift points based on the truck application or is it a physical limitation?
Old Jan 19, 2004 | 10:10 PM
DeepBlueZ's Avatar
in the truck version they lower the RATING meaning that the trans will handle such and sch and amount of torque at 5600 rpm instead of 6100 in the car version....i have the car version and its not physically limited at all i rev it past 5600 with no problem.
Old Jan 21, 2004 | 04:28 AM
Guardsman's Avatar
The 4L65E is listed as haveing a higher torque and hp rating than the 4L60E, however, the shift points are listed as being at 5600 rpm.
Old Jan 21, 2004 | 05:54 PM
DeepBlueZ's Avatar
right....mine works fine...lol nuff said.
Old Jun 2, 2004 | 12:49 PM
marc_w's Avatar
I know this is old, but I wanted to mention that the '65's are available behind every LQ9 (High compression 6.0) motor...
That's any Silverado SS, any full sized Caddy SUV.
Old Jun 2, 2004 | 04:06 PM
DeepBlueZ's Avatar
correct...however, car applications would require changing a few thigns that are more suited to the trucks. (servo, valvebody calibration, etc.)
Old Jun 4, 2004 | 04:03 PM
BAD APPLE's Avatar
Originally Posted by Guardsman
Also, there is (was) an upgraded 4L60E that has the hardened parts, it's listed as a 4L60E by GM, but it's RPO code M32 instead of M30.
That one's not quite as stout. It was developed for the old body style police tahoe.
One other too, there are two input sprag assemblies, a high speed one and a low speed one. I don't know what the differences are, though, but they are different p/ns, so double check those before you order one.
The 4L65E part has brass end bearings (gold colored) while the 4L60E part uses steel (gray colored).
That last thing that I can think of right now is that there is also a difference in the low/reverse planetary set. The 4-pinion set that comes in the 4L60Es has an oil slinger on the back of it, and oil holes through the centers of the plantetary gears. The 5-pinion planetary doesn't have either. The Camaro parts manual lists a 4-pinion planetary with the oil slinger, and one without, and says that the one with the slinger is for high output applications. What I haven't been able to confirm is whether the 5-pinion planetary gears were changed so that they don't require the oil holes any more. I haven't seen the "low output" 4-pinion planetary, so I don't know if it has oil holes or not.
The 4-pinion "high-speed" variant only came in the Corvette and V8 F-cars (this is why there are 2 pn's for F-car: V6/V8). The 5-pinion sets produced from 2001 to 2004 for 4L65E's do not have this "high-speed" oil slinger and hollow pinion pins. It's purpose is for VEHICLE high speed, not SHIFT speeds. Meaning, sustained top speed runs at 160 to 170 mph can really abuse the output carrier and pinions(imagine the output carrier and pinion speeds as they are overdriven in fourth gear at 170mph). Without the "high-speed" design, you'll eventually burn the pinions/washers. But remember, this is for GM's test of "Running the Corvette completely through one tank of gas at it's highest attainable speed." Not something the average driver is likely to do unless you drive on the autobahn (the reason the spec exists is for european corvettes). So basically those 2001 to 2004 4L65E's will work fine in your F-car. The 2005 C6 4L65E WILL HAVE a "high-speed" output carrier, it's just designed differently than the "slinger and hollow pins" 4-pinion method.
Old Jun 5, 2004 | 03:17 AM
DeepBlueZ's Avatar
in short, am i gonna have a problem with this tranny???
Old Jun 7, 2004 | 08:18 AM
BAD APPLE's Avatar
No. Just don't enter the Silver State Classic
But seriously, that 5-pinion won't give you any trouble witohout SUSTAINED high speed. Meaning, it's the heat build up over the course of a 30 to 45 minute run at top speed that'll distress those pinions. "Excusions" up to top speed won't do this.
Old Jun 7, 2004 | 01:59 PM
DeepBlueZ's Avatar
ok thanx for the reassurance....i won't have to worry then, if i left my house and tried to drive 30 minutes in any direction at 150 mph, id end up in the ocean....
Old Jun 24, 2006 | 03:15 AM
  #32
RODS01HUNTER's Avatar
Thumbs up 6-speed Auto Update
JUST THOUGHT I WOULD PASS THIS ON, THE 06, AND 07 CORVETTE WITH PADDLE SHIFT ON STEERING WHEEL HAS THE N-E-W HYDRA MATIC 6L80 SIX SPEED AUTOMATIC TRANSMISSIONS (THATS RIGHT I SAID SIX SPEED AUTO) WITH GEAR RATIO'S FIRST THRU SIX, AND REVERSE AS FOLLOWS:4.03,2.36,1.53,1.15,0.85,0.67,AND-3.06!!! MAX 413BHP/430FT LB TORQUE! THESE ARE ALSO FOUND IN CADILLAC XLR/XLRV/ AND STSV. GMC YUKON DENALI/DENALI XL. ESCALADE ESV/AND EXT!! HAVE BEEN LOCKING AT MY OPTIONS ON MY 01 WS6 TRANSMISSION UPGRADE!! HOPE THIS HELPS,RODNEY.
Old Jun 24, 2006 | 03:53 PM
  #33
AK's WS6's Avatar
Good info guys!!!
