B&M ShiftPlus Electronic Shift Improver Kits
Old Mar 25, 2010 | 06:16 PM
ramzisleiman's Avatar
Default B&M ShiftPlus Electronic Shift Improver Kits
anyone tried this shift improver.. its on summit racing.
Old Mar 26, 2010 | 09:13 AM
jimmyblue's Avatar
Moderator
You could get the same pressure effects by tuning.
The dongle will not do anything for the crappy factory
shiftpoint profile.
Old Mar 26, 2010 | 01:02 PM
72blownvert's Avatar
It's not a good idea to turn the epc screw in at all.
Old Mar 26, 2010 | 03:50 PM
ArkBird96's Avatar
That module is a bad idea IMHO. If you want your tranny to shift better, get a shift kit and a tune to change the shift points. All that box that Summit sells does is raise line pressure. In my opinion, line pressure settings are better left alone.
Old Mar 28, 2010 | 03:11 PM
how about Shift Boss Transmission Programmer ? its from TCI.. and ofcourse i am getting the overhaul kit with the shift kit.
Old Mar 30, 2010 | 04:59 AM
Old Mar 30, 2010 | 06:17 AM
darkhorsebob's Avatar
Don't most tunes raise the line pressure. Most valve body kits also raise the line pressure with P.R. spring changes.
I'm just saying...............
