4l60e transmission pan???
Old Apr 3, 2010 | 07:48 PM
NewOrleansLT1's Avatar
Default 4l60e transmission pan???
How many quarts of fluid can a stock f body 4l60e pan hold?
Old Apr 3, 2010 | 09:53 PM
Thanks. Anyone else?
Old Apr 4, 2010 | 04:29 PM
elias_799's Avatar
there is allot of variables when filling up an automatic transmission
is the converter filled ?
was the oil cooler flushed ?
did the valve body still have fluid in it ?
that is why you can not get a straight answer from anybody, best thing to do is fill up the tranny till you can see fluid on the dipstick, start, go threw all the gears and make sure you let it stay in every gear for about 3 seconds, then throw it back in park and check the level, and continue the same method if it needs more
when i changed the transmission filter and all the oil that was in the pan, it took about 6.5 liters
Old Apr 5, 2010 | 05:35 PM
I just want to drop the pan and buy some fluid. I just wanted to know how much to buy...
Old Apr 5, 2010 | 07:50 PM
joecar's Avatar
In that case, 4 to 5 quarts.
Old Apr 11, 2010 | 09:01 AM
BennyB's Avatar
what ^ he said but i would go with 6 quarts just in case
Old Apr 11, 2010 | 08:27 PM
'91firebirdformula's Avatar
then buy 7? if you dont use it take back to the parts store or keep it for future needs.
