4L60, fitting, cooler line?? HELP please
I really need your help !!!
I'm abroad with my camaro z28 1993 4L60 and I loose some transmission fluid from the transmission cooler line.
I need your help because GM doesn't produce the line assembled anymore.
Do you know where I could get a transmission cooler line assembled???
or not, do you know the references for fittings????
the ones on the transmission??
and the ones on the radiator??
I found that about the radiator but I don't if it is right : (Transmission Oil Cooler: 11 1/2 in. (4 plate)) what means 4 plate???
then can I make the line with braided hoses??? from Russell ???
do you if it is the same fittings for the 4L60, the 700R4 and the 4L60E?????
THANK YOU VERY MUCH for any help !!!!
charles
I looked on Jegs and Summit, but not lot of things for my camaro...
if I take the hose from there:
http://www.russellperformance.com/mc..._prorace.shtml
and fittings from there (it is the only thing I found on jeg and summit websites):
http://www.summitracing.com/parts/HDA-390/
should it be good???
on the summit website I can see two fittings, one for the transmission, the other for the radiator???
actually I'm in Europe and I shipped my camaro from tx. the deal is in Europe nobody drive automatic so.... the autoparts store told me to call GM....
if someone has any link, it could save me
I guess I will try to find 4 fittings then use -6AN braided hoses to make the new cooler lines.
if someone can confirm if that makes sense it should be very nice
thanks for your help !
I was thinking about braided line, because it should be more solid because the line will be close to the road (I mean close to the floor).
but if you tell me that rubber transmission cooler hoses are enough, I will try to find some. thanks
actually I'm in Europe in Austria, and the Camaro stays in France because of this problem, I shipped 7 months ago, I drove it on the German Highway
I found a guy on ebay who has thousand of them but i don't know if he has the right one ! I m going to check now
I found some one to realize a steel line, he said that he could use the original fittings....
but I prefer to have some in case of....
ACDELCO Part # 8637742 {#08637742}
FITTING,TRANS FLUID CLR PIPE w/4-SPD A/TRANS(MD8); TO CASE
$5.31 $0.00 $5.31
FOUR SEASONS Part # 53009 {Fitting Kit}
Fitting Kit
$17.63 $0.00 $17.63
EDELMANN Part # A63006 {Transmission Oil Cooler End Fitting; 5/16" Female Inverted Flare x 1/4" Male}
Outlet To Transmission (Lower)
Inlet To Transmission (Upper)
* Non-stock item--shipping delayed up to 3 business days
+ Sold in packs of 5; Price reflects cost of each individual item, not the pack
$2.17 $0.00 $2.17
EDELMANN Part # A63011 {Transmission Oil Cooler End Fitting; 5/16" Male Inverted Flare Tube Nut}
Tube Nut; As required
you can find them on rockauto, but I don't know which one could be the "good one"
or I found that:
http://www.summitracing.com/parts/ACC-74748B/
I found that, but not the good size:
http://www.summitracing.com/parts/BCI-72001/
I don't if it goes because they say 1/4 in NPT......
this one looks very good, no???
http://www.summitracing.com/parts/PRM-15165/
what is the advantage of this one???
http://www.summitracing.com/parts/DER-13031/
thank you very much for the links
actually, I can not check because my car is in France and me in Austria, but I guess I will order them.
just a last question
in your opinion it is better to make it with only rubber hoses or only a steel line? (I can't mix them like the original)
and what is the difference between 5/16" and -6AN???
