kinda shot myself in the foot
Like you said, the ties will go through the cooler, condenser, then the radiator. Right? Cut the back of the tie and pull it apart, the part where the retainer clip holds the tie string. Now, go ahead and reinstall it, just run the tie through the cooler and the condenser. There will be enough of the tie left from where it went through the radiator. With the cooler installed on the condenser you should still have enough room to move it around during the cam swap.
