4L65E/LS6 questions?
Old Jan 7, 2004 | 11:56 AM
57 Bel-air Vette's Avatar
Question 4L65E/LS6 questions?
Hey Guys, I see that they built the 65E to handle the torque of the LS6,anyone know when GM is going to offer the LS6 w/the computer and wiring harness?-like they did w/the LS1 crate engine.Will the LS1 wiring harness work the 65E tranny?
Old Jan 7, 2004 | 10:37 PM
patriot68's Avatar
Default 4l65e
the 4l65e is the same as the 4l60e..the 65e has heavy duty 5 pinion planets, hardened input and output shaft, and a heavy duty shell..you can interchange all these parts into a 60e or a 700r4. im pretty sure the harness is the same as the 60e
Old Jan 8, 2004 | 01:07 AM
DeepBlueZ's Avatar
harness should work fine.....my 65 bolted in no problem.
Old Jan 9, 2004 | 07:19 PM
Thanks
Old Jan 9, 2004 | 07:27 PM
DeepBlueZ's Avatar
no problem...
