Tranny cooler Question????
Old May 8, 2010 | 01:14 AM
bigc98ws6's Avatar
Default Tranny cooler Question????
I just bought a tranny cooler and was doing some research and seen guys where bypassing the radiator cooler.Want to know which is better bypassing or not bypassing...Even though bypassing the radiator cooler seems alot easier than not......THANKS
Old May 8, 2010 | 01:35 AM
Squirts11's Avatar
Some recommend bypassing the stock radiator/cooler, as during the warmer summer months the hot coolant temps will excessively heat the trans fluids as well.
Personally, I've always heard that running the aftermarket cooler in conjunction with the stock cooler can provide up to 30% more cooling. This is what I'm doing.
Old May 8, 2010 | 02:28 AM
7th Darkness's Avatar
This is a debated issue, but I bypassed mine. I also monitor my temp in the pressure port. My temps run about 130-150 locked, and 170-190 unlocked in 80-90 degree weather.
Old May 8, 2010 | 07:13 AM
05GTO6SPEED's Avatar
i left my stock one in because it was good enough to cool the trans stock so if i add an aftermarket one it will help even more or at least thats what i was thinking
Old May 8, 2010 | 10:00 AM
peterlawl84's Avatar
This is what I was told:
If you plan on driving it in the cold (parked outside in the cold overnight or throughout the day), then run both the stock and the aftermarket cooler in series. The stock cooler will help heat up the fluid faster.
If you do not plan on driving it in the cold, then the aftermarket cooler alone will have cooler temps because the stock cooler will have the hot engine coolant preventing the heat to dissipate from the transmission fluid.
Like I said, this is just what has been told to me by several people. I plan on running just the aftermarket cooler and capping off the stock one.
Old May 8, 2010 | 09:29 PM
98PurpleT/A's Avatar
I'm planning on running both.
Old May 8, 2010 | 09:39 PM
lordrazo's Avatar
its up to you i always suggest a small fan and big cooler i do live in Florida as well but running through the radiator first then a cooler will provide almost 40% more cooling some say its over kill but when its hot and back to back racing all can help in my book
Old May 8, 2010 | 10:30 PM
jts98z28's Avatar
im gonna be running 3, the radiator, a small tube and fin in front of the radiator and a big one dope style..... that is if i ever finish my car
Old May 8, 2010 | 11:07 PM
like i said i think more is better plus liquid to air cools better that air to air, plus there is more fluid so it takes longer to circulate wich helps cool
