4l80 in a 2010 camaro a6?
Old May 10, 2010 | 02:38 PM
bluehawk2's Avatar
Default 4l80 in a 2010 camaro a6?
i am wondering what all is going to be involved in swapping a 4l80 into a 2010 camaro a6. I know a few of the g8 guys have made this swap but has anyone done this with a 2010 camaro?
any help will be appreciated
thanks
Old May 13, 2010 | 08:32 PM
shanemilleresp's Avatar
why?
the 6l80e is a hoss dude its supposed to be stronger than an 4l80 maybe less availible parts but i dont see the advantage?
Old May 13, 2010 | 10:23 PM
STEEPSS's Avatar
X2, I'm with this guy^^^
Why not have more gears, be able to run a numerically lower rear, and get hella MPG's
Old May 14, 2010 | 05:50 PM
jakeshoe's Avatar
Originally Posted by shanemilleresp
why?
Have you ever driven a vehicle with a 6L80? It doesn't lend itself to performance use.
It's not stronger.
Old May 14, 2010 | 06:20 PM
yup sure have drivin them im a tech at a gm dealer they take off like bat from hell with that 4 to 1 first gear and there alot bigger than a 4l80e i dont see what makes them weaker?
Old May 15, 2010 | 10:04 AM
jakeshoe's Avatar
Look up "synchronous shifting" and then you'll understand why they are weaker and shift like a dump truck.
Old May 15, 2010 | 10:22 AM
Yank's Avatar
The Corvette guys are doing this but are also going back to the 4l70-E trans with all the updates as they can not get the 6l80 to live long under high hosepower.
Old May 17, 2010 | 07:11 PM
bluehawk2's Avatar
We are running a lsx 454 with two 150 stages of gas..................thats why the 6l80 wont work. It is blowing through all the shifts because the trans can't shift fast enough. The tuning for the 6l80 isnt here yet.
Old May 17, 2010 | 08:36 PM
jakeshoe's Avatar
I don't think the tuning will ever be there.
Old May 18, 2010 | 08:41 AM
Circle-D's Avatar
There are some advancements on tuning and trans durability in the works. It is a new trans still, but it will eventually hold the power you have. The upgrades may not come fast enough for you though. So tough decision, I know.
Chris
