multiple 4l60e trouble codes! please help!
Old May 10, 2010 | 05:39 PM
tylerwerrin's Avatar
Default multiple 4l60e trouble codes! please help!
Hi there,
I'm running a 96 4l60e....
I'm not sure if i'm in limp home mode, or my transmission is shot. i ran some diagnostics on my car after i could only barely go in reverse, and forward gears i just sat in one spot, even when mashing on the gas.
i ran the diagnostics and this is what came back:
p0775 -- pressure control solenoid B
p1840 -- ?
p1841 -- ?
p1851 -- ?
p0753 -- 1-2 shift solenoid A
p1864 -- TCC enable solenoid
p1886 -- transaxle shift
all of these are electrical issues with the trans -- the fluid is at *full* level right now. I checked the fuses, and they looked fine too. is this indicative of "limp home" mode? or could it be something to do with the trans plug? seems weird that all the electrical systems would fail simultaneously.
any suggestions on what to do next?
Old May 10, 2010 | 07:14 PM
performabuilt's Avatar
LS1Tech Sponsor
sounds like you have a blown fuse or a disconnected trans harness
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
