4l60 shift problems on nitrous
Old May 11, 2010 | 01:13 PM
onthabottle's Avatar
Default 4l60 shift problems on nitrous
im having problems with my car shifting from 2nd to 3rd when im spraying... it shifts perfect off the nitrous but when i spray it bangs the rev limiter like 3 times before it will shift from 2nd to 3rd is this a tranny issue or in the tune?
Old May 11, 2010 | 01:38 PM
dannyz's Avatar
Could be either.
If your running a bigger shot and the tranny's in good shape you need to bring the shift points down.
Do you have an aftermarket stall?
Old May 11, 2010 | 01:43 PM
performabuilt's Avatar
LS1Tech Sponsor
Spraying will cause the rpm to rise at a greater rate therefore you need more time from comand to shift since the time it takes to make the shift is a constant reguarless of the rate of rpm increase. Your getting to the limiter on nos before the trans can complete the shift , You will need to compensate in tuning but this will also cause it to shift earlier n/a
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 12, 2010 | 02:13 PM
i have a circle d 3600... i was playing with it yesterday and i set the nitrous to cut off 100 rpm sooner then it was set and it shifted perfect so hopefully that fixed it...
Old May 12, 2010 | 04:12 PM
lonely's Avatar
good job, do you have a video clip for your ride, I want to see how the TC act with the car, also if you can do one with spray, thanks in advance.
