Strange Shifting Problem
Old May 12, 2010 | 08:48 PM
WS6Drop's Avatar
Default Strange Shifting Problem
The car is fine when I first start it up and drive around. If I floor it around 45 and make it shift into second the car will no longer shift into 3rd or 4th gear. Occasionally it will shift in 3rd but never OD. I checked the fluid and its good, not burnt. The car has a SS3200 yank and it is a built trans supposedly made to withstand over 600RWHP. I really dont notice any slipping. I tried manually moving the shifter into 3rd and 4th with no luck. 1st and 2nd gear seem unaffected. No SES lights either. Please help.
Old May 13, 2010 | 09:16 AM
performabuilt's Avatar
LS1Tech Sponsor
even though there is no code showing it sounds like limp mode make sure that the code po757 test is turned off in tuning,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 14, 2010 | 06:50 AM
WS6Drop's Avatar
I was looking around the site and seems it could be p0103 problem as well, especially because I am procharged. I will check the po757 as well.
