Shift points for ss4000 stall?
Old May 13, 2010 | 04:33 PM
1gt2nv's Avatar
Default Shift points for ss4000 stall?
I'm getting a Yank stall in a few weeks!! What should the shift points be set at for this stall? The stall is a ss4000.
Old May 13, 2010 | 05:47 PM
SS SLP2's Avatar
Where does your cam make most money? I shift 1-2 /2-3 @6500 and 3-4 @6200 with a limiter @ 6700 with 231/237-595/598-112
Johnny
redbird555's Avatar
shift points should be the stock ones but you may wanna firm them up a bit seeing as a stall will make them feel softer, u may want to play with ur lock up speed also but that is entirely up to you.
Old May 13, 2010 | 05:55 PM
1gt2nv's Avatar
I don't have a cam yet. All stock inside. Just a bolt on car.
Old May 13, 2010 | 06:53 PM
twitchtwice's Avatar
when i got my car tuned i think it was shifting at about 6200 with the stock cam. idk what they put the limited to. im sure they moved it up so there wouldnt be any problems. now that i have a cam its shifting out at 6500-6600
Old May 14, 2010 | 06:27 PM
1gt2nv's Avatar
What should the shift points be for stock cam?
Old May 15, 2010 | 12:06 AM
LS1nut377's Avatar
with a stock motor mine was shifting at 6400, and ran great. car set to lock up only in drive at 60 mph, witch is the way i like it right now. but with the cam it shifts at 6600.
2-3 bounces a little so a new trans is in the works! then ill lock it up in 3rd WOT.
line pressures have been increased and everything done to make it shift CRISP.
just make sure to get a GOOD trans cooler! 24K B&M! I run 2 of them!
