700r4 to th350
Old Jan 11, 2004 | 08:53 PM
smoknta's Avatar
Default 700r4 to th350
I've been thinking about swapping out my 700r4 with a th350. Do these transmissions use the same torque convertor or will i have to get another. I was told that the spline is different. Thanks for any help.
Old Jan 11, 2004 | 10:35 PM
aram's Avatar
it's not the same.
Old Jan 12, 2004 | 10:50 AM
A BAD T/A's Avatar
First, you will need to install a 350 non lock-up converter. Other than the converter, there IS a kit for this conversion that comes with a correct length output shaft, a tailshaft housing spacer (you use the 700-r4 tailshaft housing), correct filler tube, detent cable and even new selector indicator decals, PM me for details!
Old Jan 12, 2004 | 05:32 PM
silverTA's Avatar
its not ganna work ,,
i installed a 350 non lock up converter in mine ,,
