Rebuilt 4L60E, No Overdrive or Lockup, Help!!!
"--3--" this is telling you it wants to lock but is held
off; usually misfires. Small diameter converters often
need misfire detects tamped down.
Similarly look at Trans Current Gear to determine intent.
If it shows 4, maybe it's just the looseness of the
converter and lack of lockup, not feeling much different
from 3rd.
If you read codes, immature codes (seen, but not enough
times to set the light) will show as such.
What kind of causes could take out 4th gear by itself? I have 1, 2, and 3 still
If you do that, you need both to ground the TCC
valve, and apply 12V to the TCC pressure control
valve (proper name?). If you don't give juice to
the pressure valve, you get 0% of line applied at
lockup.
Internally, what could cause me to not have 4th gear and torque converter lockup?
