Old Apr 26, 2016, 01:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
Auto Transmission Fluid Change
Old May 21, 2010 | 07:01 PM
ssweet98's Avatar
Default Auto Transmission Fluid Change
How often do you guys change your transmission fluid? I dont run the car hard so keep that in mind. I have a 3600 Stall Converter. Does anyone know about BG's transmission flush cleaner ? Do you recommend the total flush with the machine or have it changed manually by hand. Thanks for the help.
Old May 21, 2010 | 09:28 PM
99Hawk262's Avatar
I change it once a year in the fall. I drop the pan and replace the filter and then the 5ish quarts it takes afterwards. It's not a complete flush, but by changing it once a year it stays nice and fresh. Of course, this last year with all the converter changes I've made I've gone through a LOT of fluid. This yearly service was recommended by Vince at FLT.
Old May 21, 2010 | 11:31 PM
allbaugh_04's Avatar
Nothing wrong with once a year. Seems a bit excessive but peace of mind and cheap insurance.
If you don't beat on it much, every other year or 25k should be sufficient.
Old May 22, 2010 | 09:04 AM
01ssreda4's Avatar
I drive my car maybe a couple Ks a year and I still change mine once a year. By hand and a filter as well.
Old May 22, 2010 | 01:30 PM
Roxas's Avatar
Good info. What oil and brand of filter do you all recommend? This will be my first time changing the trans fluid in my T/A.
Old May 22, 2010 | 01:56 PM
01ssreda4's Avatar
I use the auto store filter/gasket combo and Castrol Dex. Its like $23 for a 5 quart jug, which is about what you need.
Old May 22, 2010 | 11:06 PM
dnkynrbk's Avatar
AGREE with above. I dont use syntheic.
Old May 23, 2010 | 08:45 AM
Roxas's Avatar
Originally Posted by Bro Inc
I track down SPX filters, they come with no gasket.
And use a Fel Pro TOS18663 gasket.
No chinese crap.
For fluid, closest to Dexron III that can be found.
SPX? I dont think I've ever heard of them. I'm heading to AZ in a bit, I'll check out what they have there and get a feel for the prices.
Thanks for the info!
