4500+ stall guys, have cooling questions...
I'll be running a ~5200 stall 8" spragless converter on the street, I got two of those big 11x11 b&m plate coolers... think it'll be enough to keep the temps down? Or should I look at getting a small fan for at least one of those coolers? My thinking was that I have plenty of gear to keep the cruise rpms 3k+ which should have that converter coupling up. Thoughts?
If you have a lockup 4000 stall, don't bother responding.
I have a 5000 with 3.23's and I run two coolers. One is a B&M 24K mounted dope style and the other is a Hayden that is mounted on the condenser. I also have an SLP fan switch that when activated drops the temps a legitimate 10*. My temps stay at ~150* cruising and ~180* in traffic on the hottest Arkansas days. Today was in the 80's and on the highway I was running about 120*. I would recommend a temp gauge to keep an eye on things and go from there. If the temps get out of control, you can add a fan at that point.
