Tranny cooler??
Old Jan 12, 2004 | 02:38 PM
KBoogie's Avatar
Default Tranny cooler??
I am doing a LS1 swap in to my 3rd Gen Rx7, and i just wanted to check and see if i was going to need a tranny cooler? i had heard that they didnt need them unless you planned on towing, and i dont plan on doing any of that so....
Thanks guys!
KB
Old Jan 12, 2004 | 02:55 PM
BYOFICR's Avatar
if you upgrade the converter you will need an aftermarket one. If you are using the stock on w/o the stock automatic radiator you will need one as well. The stock auto radiator has one in it but will not be enough for an aftermarket converter
Old Jan 12, 2004 | 03:34 PM
KBoogie's Avatar
Ahhh! Well i was under the asumption that the autos did not need a tranny cooler, unless you were towing.... Looks like Brian Hinson was wrong! He said that stock automatic vettes, camaros and T/A's did not have tranny coolers.
Glad i asked on here......
Thanks guys!
KB
Old Jan 12, 2004 | 05:30 PM
silverTA's Avatar
as he told u up there ,,u need a tranny color the biggest u can fit in there
Old Jan 12, 2004 | 08:12 PM
Jorday's Avatar
I use a 28000 GVW cooler with my 4200 stall converter.
