Stall lockup?
Old May 24, 2010 | 05:32 AM
tg580's Avatar
Default Stall lockup?
You'll have to excuse my ignorance here. What does lockup mean on a stall converter and how important is it?
Old May 24, 2010 | 09:28 AM
Intercooler2's Avatar
It's the clutch inside that takes the slip out and helps MPG. You a must unless you set the trans up for a non-lock converter. More heat with a non-lock too!
