Another Trans Cooler Question!
Old Jun 2, 2010 | 02:35 PM
Ruedy4's Avatar
Default Another Trans Cooler Question!
My father-in-law had this sitting in his garage and told me if i can use it i can have it. Well i was hoping with these pictures you guys might be able to tell me if it will work on my '00 TA and what i will need to get to make it work. Its about 10 1/2in by 71/2in in size and it is not leaking (as far as i can tell) Any help would be appreciated!
Attached Thumbnails Another Trans Cooler Question!-061.jpg   Another Trans Cooler Question!-063.jpg
Old Jun 2, 2010 | 03:30 PM
allbaugh_04's Avatar
I doubt there is any names or part #s? Should work, but I would recommend cleaning it out.
Old Jun 2, 2010 | 05:09 PM
Ruedy4's Avatar
unfortunately no. i can't seem to find any part numbers on the thing. all it says is CANADA on the mounting bracket portion. i figured i would be better off buying a new one but i just wanted to see if i could save about fifty bucks and maybe just purchase the install kit. It looks like all the rest with a slightly diff. design.
Old Jun 2, 2010 | 05:29 PM
whtrashferrari's Avatar
Default clean it!
make sure you clean it good !
Old Jun 2, 2010 | 05:36 PM
ronsws6's Avatar
Flush it real well to make sure its not clogged by god knows what and after you install it, check thouroughly for leaks.
Old Jun 2, 2010 | 06:10 PM
Ruedy4's Avatar
what would you guys recommend using to clean it out?
Old Jun 2, 2010 | 06:13 PM
Ruedy4's Avatar
i used my hose to spray water through to make sure there were no clogs and water seemed to flow through B-E-A-utifully! but i'm sure something else would work better to help get crap out.
Old Jun 2, 2010 | 08:15 PM
Brake Kleen should work or a air compressor maybe.
Personally, for the amount a cooler costs, I would just get a new one that you know cools well.
Old Jun 2, 2010 | 09:20 PM
supermouse4's Avatar
I would use some acetone or another solvent like that to clean out that cleaner. If worse comes to worse, use some warm soapy water with an air compressor.
If you have the money, just purchase a new one and don't worry about cleaning that cooler out.
Old Jun 2, 2010 | 10:22 PM
Ruedy4's Avatar
yeah i'm leaning more towards just getting a new one i guess----less hassle. now i have researched as much as i can about how to install these but any info/pics you guys have would be helpful. Especially if you guys have any pics on where your connecting the hoses and how your running them.
Old Jun 2, 2010 | 10:52 PM
Ruedy4's Avatar
Originally Posted by Bro Inc
DO NOT put water in the cooler. What the hell are you guys thinking?
This isn't all about looks, you need to think about whats inside the cooler, NOT the fins.
You can use a whole can of brake cleaner or two, or lacquer thinner. But you need to blow it out with a good amount of compressed air.
I've seen a lot of **** come out of coolers, and looking at the design of that one, I'd say buy a new one like a B&M and throw that one in the garbage.
You're looking at $50 to $90 for a new one, or possibly $2,xxx for a new transmission. Whats a better deal?
haha agreed and since i already flushed it out with a garden hose i'm gonna chawk it up as an epic fail and call it a day! better safe than sorry! thanks for your help guys. now can anyone point me in the direction of some decent install pics?? i'm a visual type of guy-you can tell me what to do all day but unless i see it i'm getting nowhere.
Old Jun 2, 2010 | 11:18 PM
I can take some, but my car won't be back till Sunday.
Old Jun 2, 2010 | 11:42 PM
Ruedy4's Avatar
i'm willing to wait my friend. Thanks i would really appreciate it!
Old Jun 3, 2010 | 08:21 AM
1993 z28 f1's Avatar
Hey:
Buy a Setrab, B&M, Derale, Hayden, Perma Cool, or Longs low pressure drop, stacked tube and fin type cooler, about 25,000 BTU or bigger, if your going to be running a fuddle. Some companies list them for towing, or RV use and rate them in GVW, you still you want 25,000 plus. If you use it in really cold weather or as a daily driver get a cold weather thermostatic bypass valve as well. If you use it only in the hot summer for long cruises get a electric fan kit for the cooler, you'll need it.
Dub
When In Doubt Do Without
Old Jun 3, 2010 | 08:46 PM
Ruedy4's Avatar
Originally Posted by 1993 z28 f1
Hey:
Dub
Hey thanks a lot for the help. Do you have any idea where i can find that thermostatic bypass valve and how much it might cost? i have never heard of anyone using one before. Thanks!
Old Jun 10, 2010 | 12:28 PM
ronsws6's Avatar
Um.. Not to cause any flames, but I have flushed coolers with SOAPY Water about a gazillion times, then clean water, then compressed air to get the water out without any failures. But YMMV. If you flushed it and immediately assembled it while there was still water in it you could kill your tranny though.
Old Jun 10, 2010 | 12:43 PM
01ssreda4's Avatar
Thats a company called Long. All B+M coolers have this printed on them as well. Apparently one big factory makes them, then sells to different companies who then put the coolers in their own boxes and sell them under their own name.
I wouldnt use a used cooler.
