Shifting out of Park
Old Jan 14, 2004 | 12:58 PM
RyanJ's Avatar
SSU Moderator
Default Shifting out of Park
Recently I have been experiencing issues getting the button pressed on my TA handle to get the shifter out of Park. It acts exactly like I am not pressing the brake hard enough or even at all; no matter how hard I press the brake pedal.
Has anyone experienced the same thing? Any easy fixes that anyone can think of? Shifter ****/button? Actual shifter? Trans?
I thought maybe the safety mechanism was boned, but I have touched nothing on the trans since my converter install 2.5 years ago.
Any thoughts??
Old Jan 14, 2004 | 03:03 PM
gojo's Avatar
Any thoughts??
Mine has done that in cold weather. I think if the switch on the brake pedal is adjusted tight it may release a little slower in the cold.
Old Jan 14, 2004 | 05:04 PM
RyanJ's Avatar
SSU Moderator
where is the switch on the brake pedal? Can it be manually adjusted? Anyone have a helms manual they can scan or something?
Old Jan 14, 2004 | 05:28 PM
gojo's Avatar
There is a cover under the dash , over the brake pedal. It's held on by two plastic snaps(or whatever they're called) and a metal clip. You will the see the switches underneath. There are brake light and gear selector safety switches. I tried to unclip one and the middle plastic clip snapped so I gave up.
Old Jan 15, 2004 | 10:34 AM
RyanJ's Avatar
SSU Moderator
lol. any thoughts on just unhooking the safety switch?
