tranny temps
Old Jun 17, 2010 | 07:28 AM
z28_n_tx's Avatar
Default tranny temps
finally go tmy tranny temp gauge hooked up, so i wanted to know what the stock tranny temps are?? i havent added my 24k cooler yet. but yesterday after work drinving about 30mile trip temps got as high as 190-195 close to 200, in 95 degree weather (felt more like 100+) is this an ok temp. sending unit is located in the pressure port for now. and is it 10-15 more with it being installed there, right??
Old Jun 17, 2010 | 08:38 AM
01ssreda4's Avatar
Yes, it will show a higher reading there in the pressure port. If its as hot in TX as it is here, I'd say you are doing pretty good with those readings. Bypass your stock radiator cooler as it actually acts as a warmer and you will see the biggest drop in temps. Run your standalone B+M by itself.
Old Jun 17, 2010 | 10:26 PM
SS SLP2's Avatar
YANK said 200 and under would be best and stay under 210-215,I bumped 218 for a few minutes and will be changing fluid
ps in the pan
Johnny
Old Jun 18, 2010 | 06:47 PM
02 BLK WS6's Avatar
Anything under 200* is fine. In the summer heat mine stays in the mid to upper 170's.
Old Jun 19, 2010 | 08:17 AM
z28_n_tx's Avatar
cool, il beinstallin my cooler soon and than my tc....
Old Jun 19, 2010 | 04:52 PM
twitchtwice's Avatar
im located in texas as well. mine doesnt get over 180 in the dead heat of the day so with a cooler you'll be fine.
Old Jun 19, 2010 | 08:10 PM
cabech984's Avatar
Is it normal for the tranny temps to go above 200 during drag racing and hard driving?? Mine is reaching 250 degrees during full throttle acceleration.
Old Jun 19, 2010 | 09:19 PM
allbaugh_04's Avatar
That's definitely not a good temp to be at.
Do you have a cooler? They are very easy to install, you should get one.
Old Jun 20, 2010 | 10:51 AM
355TurboLT1's Avatar
Also look into a good synthetic ATF. I run Redline and it does reduce operating temps when your beating on it. Amsoil is also another choice,although I like that redlines approach to formulating fluid isn' a one or two atf's fits all. As heat kills transmissions, fluid and cooling is VERY important followed by upgrading filtration. A drop of 10-20 degrees is usually observed when switching to a quality synthetic atf. They can also be kept in service twice as long,everything else being equal.
Old Jun 20, 2010 | 02:36 PM
Bill Bowling's Avatar
What Redline do you use? I was thinking of changing.
Bill
