Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
- Camaro and Firebird: Transmission Cooler Information
Important information to help you understand your Camaro or Firebird
Everything you need to know about tranny coolers (4l60E F-Body)
Should add that plate style coolers are more restrictive on fluid flow. You wouldnt want to say chain 2 or 3 small ones together for more cooling, at least not in series anyway. This restriction can cause trans problems as well as pushing forward on the crank causing thrust bearing failure in an engine.
Tube and fins flow very well but dont cool as good, stacked plate cool better but dont flow as good. You cant have your cake and eat it too you know. Basically what I was saying was this: you dont want to run multiple stacked plate coolers inline with each other. Get ONE big enough to handle your cooling needs. Also, consider not jacking with your line pressure settings in your trans too much. Bc, increased restriction causes upped line pressure, and computer tuning can equal increase line pressure....see what I mean. Too much line pressure and things go boom.
So if I got a decent size stacked plate cooler to go in front of the radiator I would be fine but it just wouldn't flow the greatest? You gotta wonder what is the point than if neither really do justice. Why not just get a fin type and call it a day then. It would be +1 over stock anyway.
Running one plate cooler and bypassing the stock radiator (if you dont live in extreme cold areas) is perfectly acceptable IMO and should not increase fluid restriction. Running two coolers (stock and a plate) will obviously increase restriction bc now there is a second cooler to go through. A tube and fin cooler is no difference for the fluid then just traveling through a straight piece of hose. However, look at the cross-over tubes on a plate type cooler, they are tiny.
Tube and fin flow better, but tranny coolers arent put on the increase flow ...
The only time you need to worry about the stacked plate being a restriction is if you plan on running more than 1 cooler in the same tranny line. You shouldn't need more than one cooler in most cases.
I have been logging my trans temps on the highway, and driving around in our beautiful 100 deg Miami weather with the a/c on full blast and even making some wot rips. I Have found my trans temps reach 178deg or so at its highest point. I have bypassed the stock cooler and run a smaller B&M "fin" type cooler.
Personally, I think that stacking coolers is excessive. If anything just run the 70264. I have used this one multiple times, and have had good luck.
Pontiacerator
First of all, nice write-up. I'm going to put in a word for the benefits of the tube and fin type cooler. I use the install described in this thread: https://ls1tech.com/forums/automatic...ny-cooler.html
Although the T&F might not be as efficient, mounted this way it is in completely open air and not backed up against a hot condenser/radiator. It gets all the airflow routed to the radiator but not the extra heat. For that reason, it is probably more efficient. Here's a pic from that thread:
#33
#34
http://www.bmracing.com/PRODUCTS/Universal-SuperCoolers
Or if you like you can go to Thunder Racing to purchase it. Really fast shipping!!
http://www.thunderracing.com/shop-by...olers_116.html
#35
Nice write up. I personally run just one aftermarket tranny cooler and bypass the stock one. I do this for insurance that if the radiator goes south it doesnt take the transmission out as well. With a 24k gvw cooler, bumper to bumper traffic, 85+ degree day and a yank ss4000 mine has never gone over 195 degrees. What ever floats your boat I guess.
#37
Back from the dead
Can people list the largest coolers they are running currently?
I'm trying to decide what size and brand, I'm looking at the Hayden 26,000 gvw transmission cooler but I don't know if it will fit infront of the radiator. Does anyone know?
Also are the fittings for the connections 3/8ths?
Anyone with any info I would greatly appreciate the help I'm new to this stuff and doing want to make a n00b/rice mistake.
