A4 shift problems after ported TB install
Old Jun 30, 2010 | 06:55 AM
mitmot77's Avatar
Default A4 shift problems after ported TB install
Was just wondering if there are any problems associated with the tranny shifting if installing a ported throttle body. Just wondering. I am thinking about buying one and heard some people have had problems w their trannys shifting.
Old Jun 30, 2010 | 07:00 AM
VincesSS's Avatar
Transmission shifts on vacuum.. check for vacuum leaks.
Old Jun 30, 2010 | 09:24 AM
jimmyblue's Avatar
Moderator
If you clown-port it and make it so you have a TPS fault
at the end of it all, you'll see the trans short-shift. Can
be from over-aggressive bump-stop grinding, allowing TPS
to go over the top in voltage.
Old Jun 30, 2010 | 10:41 AM
mitmot77's Avatar
Good to hear. Thanks for the quick replies.
