Stripped converter bolt
Old Jul 4, 2010 | 05:15 PM
Chubbz155's Avatar
Default Stripped converter bolt
I am doing my trans/converter swap and in the process of removing the Allen head bolt that holds the converter in I stripped the head of the bolt out. I am looking for some suggestions on getting it out. Thanks!
Old Jul 4, 2010 | 07:01 PM
mwg2600's Avatar
Vicegrips, or blow the head off the bolt with a cutting torch but then you will have to remove the threader part of the bolt. you could grind the head off also. Once you get the head off, center punch the threaded part and drill a hole in it for an easy out. Normally a reavarse drill bit will take them out without much trouble.
IF its in there from the factory or elsewhere it might have locktight on it. might need some heat to melt the locktight.
Old Jul 4, 2010 | 07:31 PM
w3s1c0a5t's Avatar
Heat helps a ton.
Old Jul 4, 2010 | 07:37 PM
JASON 77's Avatar
yes lil propane torch goes long way. also inside is allen the outside i think u can still use a socket. but heat first.
Old Jul 5, 2010 | 12:46 AM
SSHAWK's Avatar
They also make a round off bolt kit you could try. You can get them at Sears for like $10 or so.
Old Jul 5, 2010 | 04:53 AM
blk/slvr02ss's Avatar
I just helped a guy out w/ this problem.U need a center punch w/ a nice sharp point on it and dig it into the corner of the bolt to get a good bite and hit it w/ a big hammer in the direction to loosen it.Worked great for me.
Old Jul 5, 2010 | 08:11 AM
BlackScreaminMachine's Avatar
Internet Mechanic
A good set of EASY OUTs that grip on the bolt works wonders or like said cutting it off and then sending it out to be tapped and cleaned.
Old Jul 5, 2010 | 08:28 AM
Chubbz155's Avatar
Hey thanks to all you guys for your help! I got it OUT!!!! I used some heat and a set of easy outs from sears!! Thanks again!!
Old Jul 5, 2010 | 08:35 AM
Internet Mechanic
Bingo, Bango!
Old Nov 9, 2010 | 05:03 PM
SILVER 2288 SS's Avatar
From: boaring place where theres more cows than people
how did you get the easy out to work i know this is an old thread but im having this problem now
