Is my trans on its way out?
But the idle could be the idle air control valve stuck, in gear the valve opens up more because of more load to let in more air, in park or neutral it closes more because there is less load on the motor... Same thing happens when you turn the a/c on.. Turn on your a/c and see if your rpms bump up a bit at idle.
